Raeding in metadata from Windows folders
I have the tedious task to count folders and subfolders in order to determine a certain count. Does anybody have a sheet, preferably in MC15, that can count folders and access the date of creation of said folder?
Thanks in advance
Raiko
A little addition to help. I have added in a component from Richards collection which will allow you to select where folder and the relative path will be returned.
Would something like this work for the first part?
Raiko17-PeridotAuthor
Hello Mike,
thanks for responding. Can you give me an instruction on how to use your function?
Raiko
Hi Raiko,
The fuction was actually posted a while back by Philip Oakley. However, you will need to change the path "C:\YOUR PATH" to point at the folder were you want to count the files. Then you will be able to progress from there.
