RC Columns submited to Combined bending and compression
Hello, everyone.
I'm trying to create a MathCad sheet to dimensionate RC Columns submitted to Combined Bending and Compression, but I'm having trouble finding materials about this in the internet, mostly MathCad stuff. I was wondering if anyone has a sheet that calculates this or something similar to this, that could be sent to me.
Thanks in advance,
Daniel
You are searching Mathcad-sheets (15 or Prime?) in the field of Finite Element Method?
Hello, Valery. Thanks for the answer. I'm looking for MathCad 15 sheets. I don't think its related to FEM, I'm basically trying to make a sheet to calculate the required area of reinforcements to equilibrate a section, the user would input the moments in both directions and axial force as well as the section geometry and location of RC bars. Theres an attached file, its an article that does what I want but in another language, I'm having trouble translating this to MathCad, thats why I'm looking for similar sheets.
No problem to recreate this program (QuickBASIC) in Mathcad.
Mathcad has the Solver and we do not need to create and call the Newton-Raphson procedure.
You can begin and we help if you need!
Val
PS
I have written in 1995 one book on Quick BASIC
http://twt.mpei.ac.ru/ochkov/QB_QB_BC/index.htm
23-Emerald I
You can search (I used "concrete" rather than "column") and find a lot of sheets about reinforced concrete columns.
Thanks for the answer, Fred. I will search, indeed I have been looking for "skew bending" "columns" "compression" but not concrete, should have started from basic.
Please find in attachment "Columns with pinned ends and other support conditions" worksheet (for Mathcad 11, 14/15 version).
