Re: An unhandled exception
As per this thread - same issue
Hi Luc Meekes
I have probably the same problem. I have renamed the png files but I do not know how to correct the reference to it.
It is also a very important file for my diploma thesis.
Thank you so much for your help!
LucMeekesAnswer
23-Emerald V
Here's your file that opens in Mathcad Prime 7.
I've had to delete several pictures, all those pictures that contain a period inside the file name such as
image190.1.png.
You need to put them in again, but before you do, change the period in the file to something else, e.g an underscore. So rename image190.1.png      to      image190_1.png
before you put it back in.
LucMeekes23-Emerald VAnswer
23-Emerald V
image190.1.png.
Hi Luc
Thank you so much!!!
You saved me!
Danke vielmals!
