Nov 10, 2025 3:43 AM UTC
Re-read Excel Data?
Is there a way to re-read Excel Data that has been imported into PTC Mathcad using READEXCEL?
At the moment the only way I know how to re-read the Excel data is to delete the following and re-import:
Werner_EAnswer
Nov 10, 2025 3:47 AM UTC
How about letting the worksheet recalculate (Ctrl+F5) ?
As far as I see its only possible to recalculate just a single region (F5) if autocalc is off - not a particularly sensible implementation.
To Control a Region Calculation
BTW, it should not be necessary to delete the whole assignment and retype or copy it. It should suffice to change a small detail. E.g. you may delete the "2" in "data2" and (without leaving the region) immediately retype it.
Werner_E25-Diamond IAnswer
Nov 10, 2025 4:30 PM UTC
Both methods worked.  Thank you!
