RE: "Unitless" Argument Type Error Using "Re()" Command
  • December 29, 2011
  • 2 replies
  • 3038 views
Mathcad 15 returns a "This value must be a function, but has the form: Unitless" error with any type of argument I try calculating the real component of. I am using Mathcad 15 and I have units turned off. The "Im()" command works fine though. I am trying to compute the real part of a function's values ( Re(func(f))) ) but I continually get this error. As a sanity check I tried it using real and complex numbers but it does the same thing (however Im does not). As if that weren't weird enough, the "Re()" command works fine in another worksheet and I can have both open simultaneously.
Since it's clearly a worksheet specific problem, we need to see the worksheet. Please post it (in the edit dialog, click on "Use Advanced Editor" at the top right).
aroberts1-VisitorAuthor
Thanks but I figured it out. I'm a dope and defined a variable as "Re" and that screwed things up. I renamed the variable and that corrected everything.
