Mar 10, 2019 9:50 AM UTC
Returning a symbolic matrix from a Custom Function
I want to do a custom function that receives a file name, and reads a matrix of symbolics, and return this symbolic matrix do Mathcad.  For example, my file may contain the following 3x3 matrix:
a                        b+c8           k/e3
0                        5+f4            0
(6*a)/(b+c)        0                 1
numbers are numbers, symbols are k, a, e3, c8, etc.
Anyone knows how to do it?
LucMeekesAnswer
23-Emerald V
Mar 10, 2019 10:34 PM UTC
You're not the first to ask, and probably not the last either.
Consider this function:
As you can see, it is possible in Mathcad,
BUT... you need Mathcad 11.
It is the only version that has a sufficiently large undocumented access to its symbolic processor, allowing the String2Expression() function to operate by its name.
Mar 10, 2019 10:04 AM UTC
I guess that you are out of luck and that its not possible to achieve in Mathcad what you are asking for.
What you read in from a file would be a text and it would be necessary to create variable names based on that text. Unfortunately we cannot create variable names in Mathcad other than typing them in manually.
LucMeekes23-Emerald VAnswer
23-Emerald V
