Returning Multiple Values from a Function
- 3 replies
- 7678 views
- Translate All
Good morning,
I have been working in a problem that requires several steps in one function. Is like creating several tables and each one with specific information. At the end, my interest is the final value of one of those "tables", but it would be nice if I can show the result of the others tables (the entire table). Please see attached example, to understand a little bit more my issue: There are two functions ("Func" and "Func2" they are the same but they have a different return) with a loop. In each iteration I am creating a new row of each "table", and using that information I estimate the next. The tables should handle units, so that's why I use arbitrary units in this example.
My question is: as you can appreciate I use two functions to get the required value and the "other tables", but they are actually the same. do you know if there is any way I can get all (value and "tables") from the first function? something like multiple return?
Thanks a lot,
OJ.
