Jun 10, 2013 2:21 PM UTC
RLC Circuit Analysis
- 26 replies
- 41115 views
- Translate All
About this worksheet:
- Calculates the impedances across frequencies in a RLC passive crossover network
- Applicable in electrical engineering, electronics and high-tech industries, speaker design
- Performs using Excel, frequency, resistance, capacitance, inductance, angular frequency, reactance, impedance, etc.
This worksheet using PTC Mathcad includes an example of an engineer designing a hi-fi speaker that must meet a certain frequency response. The horizontal trend must be over the whole spectrum of the audible range with a tolerance of +/- 1dB. Because at least two transducers are needed, you must look at the case in which there is both a low and high frequency driver. You can calculate the impedances of each to determine the overall frequency response. This worksheet uses data from excel and plots the solutions.
Download and explore this worksheet yourself! You can download a free lifetime copy of PTC Mathcad Express and get 30 days of full functionality.
