20-Turquoise
Rotate a quadrilateral in 3-D ? (cont.)
Hi Everyone.
From the following:
    With Werner's, Terry's, and Tokoro's suggestion in thread: "Rotate a quadrilateral in 3-D ?"
Terry's suggestion with the program function but without a plot of quadrilaterals on the Graph. And Tokoro's suggestion with the figure but without a program function! Even if having the screenshot of his program function but that have not helped much to everyone in forum:
So, now, I guess I should make a new thread, and from the following :
"How to Rotate a quadrilateral and, Plot Its Image and fill different color between two of quadrilateral on the Graph ?"
Thanks in advance for your time and help.
Best Regards.
Loi.
Werner_EAnswer
The question about how to rotate around the z-axis was already answered in the other thread!
Can it be that you are simply looking for a function like the following because you don't know how to apply the solution given here
https://community.ptc.com/t5/Mathcad/Rotate-a-quadrilateral-in-3-D/m-p/815637/highlight/true#M202315
to the structure you use to plot the quadrilateral?
terryhendicott
The question seems to get longer with each answer?
lvl10720-TurquoiseAuthor
20-Turquoise
Hi, Terry.
I follow your instruction like as:
But I still get like as:
By the way, "How to 'Fill Surface' 2 quadrilaterals with fill different color for each one. ?"
Best Regards.
terryhendicott
Try referencing just the file 220828-Quaternions.xmcd not self referencing 220828-UseQuaternions.xmcd.
You cannot put a reference to the same file as Mathcad will protest.
Cheers
Terry
Werner_E25-Diamond IAnswer
Of course you can apply the function to any surface in the usual Mathcad structure
