rotating co-ordinate system with multiple vector and through range of angles?
- 7 replies
- 3642 views
- Translate All
To all
I am looking for the mathcad syntax to carry out the rotation of multiple vectors through a range of angle (from 0deg to 90 deg).
I have a number of vectors containing 3 values (Nx,Ny,Nz) given in a reference co-ordinate system (fixed) (subscript ac)
A local co-ordinate system (subscript ‘) is defined
I am attempting to write the operation of rotating the local co-ordinate by angle theta (around Xac axis) to get the new vector values (in the
local co-ordinate) - for each vector and through the whole range of angle.
I am struggling a bit with the syntax required and any help would be appreciated. Attached a mcad sheet
Thanks in advance
Regards
JXB
