RUNNING MATHCAD OVER DIFFERENT INPUT VALUE AND EXPORT SEPARATELY
- 7 replies
- 3531 views
- Translate All
Hi everybody,
my question is very simple but, as the same time, a bit complicate.
I would like running a Mathcad sheet over different input values. At the beginning, I solve the problem with equations in vector modus, but I need increase the calculus with several conditionals and complicate equations. Vector modus gives me a lot of problems and the number of table rows will change.
I thought, maybe it will be possible runs equations on each table rows (from 1 to N) and export results to an Excel files. Is it possible?
Another idea was running Mathcad sheet over different input excel files. Output results would be exported and stored to each excel file. ¿?
Thanks in advance.
You are great
