Save crash mathcad prime 10.0.0.0
I got a new pc with windows 11 home and with an intel core i7 ultra. I installed mathcad prime 10.0.0.0 with the license from my university in denmark. When trying to export or save the document it crashes. I have tried contacting my university IT-support but they say they cant help because they dont work with the program. I have read on forums that updating to the version 10.0.1.0 solves the crashing problem. Unfortunately my university does not supply license to that version. What can i do?
Thank you all for the help. I managed to reset my computer from scratch and downloaded the program once more. Probably a rookie mistake but again thanks for the help, the problem is solved.
I am not aware of a crash problem which would be fixed in the interims version 10.0.1.0 but that does not mean that its not the case. After all PTC unfortunately does not provide a clear list of improvements in new versions.
But as far as I know, versions 10.0.0.0 and 10.0.1.0 share the very same license. If you are able to download 10.0.1.0 from the PTC HP you may try to install it and use the license file you already have.
As far as i know am i not able to utilize my university account to log onto ptc. I only have access to a page with software downloads supplied by my uni. Here i found and downloaded mathcad prime 10.0.0.0. So im very interested in finding out where the problem lies. If its my computer, the software or a licensing problem i have to contact the university about.
What exactly is contained inside the worksheet you want to save/export?
I tried saving with several pages of engineering calculations. I have also tried saving an empty document several times. Either way it crashes when trying to save.
With a new PC, are you using a product like OneDrive?
@William_G123
Can you provide a link to the forum post which explains that the error/bug is fixed in 10.0.1.0 ?
I made a quick search here in the forum and also in the knowledgebase but wasn't able to find some hint about this error. But then that system is quite a messy pile of junk where you'd be very lucky to find anything useful.
If 10.0.1.0 really had fixed the problem, maybe someone from PTC (@DJNewman ??) could provide a download link for this version and can confirm, that the license file the user already has for 10.0.0.0 will be valid for this interims version as  well.
As the user had written he has no access to PTC_s software downlaod page and can only access the software provided by his university and that's just 10.0.0.0.
William_G12312-AmethystAuthorAnswer
