8-Gravel
Feb 21, 2025 4:45 AM UTC
Scalable vector file
Is it possible to export out a scalable vector file from Mathcad prime worksheet? If yes how can I do that?
terryhendicott
Feb 21, 2025 5:34 AM UTC
There is no means built specifically into Prime to construct and save SVG (Scalable vector graphics) files.
SVG files are simply text files so it is possible with a bit of work to construct a matrix of SVG text and save this with Prime function WRITETEXT to an *.svg file..
Cheers
Terry
Community Moderator
Feb 21, 2025 5:22 AM UTC
Hello @JH_9781973,
Thank you for your question.
I'd like to recommend to bring more details and context to your initial inquiry.
You could add details like:
  1. Have you tried any methods or tools so far to achieve this? If so, what were the results?
  2. Could you share more about the content of your worksheet and what you aim to export?
It also helps to have screenshot(s) to better understand what you are trying to do in your process.
Vivek N
Community Moderation Team.
terryhendicott
Cheers
Terry
terryhendicott
Feb 22, 2025 2:24 PM UTC
Have enclosed extra function that deals with the quotation marks
Community Moderator
Feb 27, 2025 6:16 AM UTC
Hello @JH_9781973,
It looks like you have some responses from a community champion. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Vivek N.
