Scalar Values from VLOOKUP?
  • December 7, 2010
  • 13 replies
  • 7864 views
I've used some VLOOKUP functions to extract data, for instance the yield strength of a material if the material name is known. Unfortunately the value returned is an array (a 1 x 1 array, but an array nonetheless). Using this in a logical equation in an "if ... otherwise" program ( if x < y where the y comes from the VLOOKUP) does not seem to work. I get an error message that the computed value must be a scalar.
How do I convert the value to a scalar?
Thanks!
Best answer by StuartBruff
select the expression that contains the result and apply the matrix subscript operator ('[' from the keyboard or from the matrix toolbar) and type 0 (assuming that you have selected 0-based indexing for matrices).
eg (taken from the lookup Quicksheet - you can get to it from the Help on lookup functions)
model:=vlookup(9, CARS,1)
model = (15)
model[0= 15
or cut out the middleman
model:=vlookup(9,CARS,1)[0
model=15
23-Emerald V
December 7, 2010
model = (15)
model[0= 15
model=15
Thank you, Stuart!
