Apr 4, 2024 9:13 AM UTC
Sensitive starting values
- 5 replies
- 1929 views
- Translate All
A friendly hello,
In the attached calculation it is easy to see from the angle sums (they must be 180°) that coarser starting values produce less precise results. Are there settings in MC14 that achieve good calculation results even with coarser starting values? Currently, the iteration can only be made successful in the sense of a fixed point equation with almost exact starting values.
