Shear and Moment diagram in Mathcad Prime 3.0
I need help to plot the shear and moment diagram of the one of the videos I have tried to use examples but it is big no go for me. Just so you know I am not coming at this completely blind. I have tried these examples :
Load Shear Moment Diagram with Mathcad.avi - YouTube
shear and force diagram in mathcad pt 1 .mov - YouTube
I think they are using some different Mathcad that I can't use in own version of Mathcad. If I could figure out how to set up the function to graph and then the plot. I think if I try simpler ones then maybe I can move on to more complex ones that I am currently working on.
thank you in advance for any help.
rpayneAnswer
I got somewhere but it says remove the complex part. See images. problem3 part 1.JPGproblem 3 part 2.JPGproblem 3 part 3.JPG
Hello Robert,
At first sight it uses MathCad 15.
Kind regards.
Denis
23-Emerald I
I can't look at your videos, but shear and moment are not difficult.
Attached is Prime 3.0
rpayne1-VisitorAuthor
That worked perfectly. Thank you. However, I am not sure of the one side open squares you have below R 0 and R 1.   This isn't my homework problem. I have much more difficult homework problem.
Calculating the shear, moment and a number of other items is not that hard.
I have attached a similar example done using a finite element model that I sometimes use (Mathcad14).
Jack
