23-Emerald I
This can open with Mathcad 15.
What version of Mathcad do you have?
jgrady1-VisitorAuthor
unfortunately 7 😞 advocating for new version but don't have funding yet. Could you post a pdf of the file for me?
thanks fred
-MFra-
It is not .pdf, can it serve the same?
Here's the pdf with all collapsed areas opened und some inserted page breaks for better readbility.
I also add the file in Mathcad 11 format - maybe someone with Mathcad 11 can convert it to MC 7 format.
23-Emerald V
Attached.  saved as Mathcad 7.
It gets big, because when saving as, everything that Mathcad 11 'knows/thinks' is not supported by mathcad 7 is (also) saved as a picture.
Obviously the collapsed regions are not supported.
Would they save as needed if you open them first?
This document was created in Mathcad 12 version. So you can open it with Mathcad 15 30-day trial version: Thank You for Your Interest in PTC Mathcad 15 | PTC
