Sep 19, 2025 2:24 AM UTC
siosolve block for functions
Saludos comunidad, tengo un problema con la solución a través de un bloque solucionado para determinar los diferentes valores detallados.DC_11916766_0-1758248874077.png(PTC Mathcad Prime 10.0.0.0)
  • El problema que tengo es que el resultado para cada fila de la matriz g es el mismo, y no debería ser así, específicamente
  • Gracias por su atención
terryhendicott
Sep 19, 2025 10:32 AM UTC
(i) ¡Cuatro ecuaciones y una restricción para encontrar siete variables no funcionan!
(ii) ¿Mx, My, Ps deben estar en las ecuaciones del bloque de resolución para usarse como entrada en el bloque de resolución paramatizado?
(iii) ¿Las funciones Q1, QQ1, Q2 y QQ2 calculan vectores y devuelven el último elemento calculado del vector, que se equipara a valores individuales?
Si desea generar el vector, indique valores de retorno específicos.
(i) Four equations and a constraint to find seven variables does not work!
(ii) Mx,My,Ps must be in the solve block equations to be used as input to paramatized solve block?
(iii) functions Q1,QQ1,Q2, & QQ2 calculate vectors and return the last thing calculated which is the last element calculated of the vector, and are equated to single values?
Put in specific return values if your intention is to output the vector.
Emeritus
Sep 26, 2025 4:05 AM UTC
Hello @DC_11916766,
It looks like you have some responses from our community champions. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
Sep 19, 2025 3:09 PM UTC
Puhhh!
As you only have four equations but look for seven variables, you sure have to investigate further and find three more equations.
Your Q1 and Q2 function seem to be completely identical apart from using different names for the input and local variables. You have to understand that the formal argument names may, but must not be of the same name as the variables you later use for calling the function. And the local variable used to hold the result of your function bust not have the same name as the function!
Because you want you solve block be dependent on three values Mx, My and Ps, these values must be arguments of the functions used in the solve block.
Its not necessary to define qn.min and qnmax in the solve block. They already were defined a the top of the sheet.
Generally I would advise to set up the solve block and the functions used therein to utilize just scalar values. Forget that later you want to feed them with vectors.
This means that you solve block should be set up and tested(!) to work with single scalar values for Mx, My and Ps. This also means that your function Q1 etc. should not treat Max etc. as vectors.
Once the solve block works OK you can call it with the vectors you provided for MX, My and Ps and create a table in the exact way you did.
Its also would be possible to call the solve block function vectorized but this would create a nasty nested matrix, so your approach for creating a table is preferable.
I tried to streamline your four functions Q1, Q2, QQ1 and QQ2 and ended up with just two functions Qmin and Qmax. But I am absolutely not sure if I correctly understood what you were trying to achieve, so you will have to thoughtfully check them!!
 So far I get a result from the solve block, but the values are far off compared to the table of desired values you posted.
You also can see how Prime deals with the fact that you provide just four equations but want it to solve for seven variables. This basically means that we have an infinite number of solutions for each input triple MX,My,Ps. And we could chose three values at random and then solve for the other four.
Prime seems to do just that and often does not change some guess values but rather returns them unchanged.
BTW, I changed your guesses for alpha, Qmin and Qmax. You have a constraint for alpha that  it should be a value between 1 and 1.5, so why do you provide a guess of 0.5?
And the values for Qmax and Qmin you expect are in the magnitude of 10-12 tonnef/m^2, so I changed your guess of 1 to 10.
Using your original guesses Prime would not find a solution for some values of Mx,My,Ps.
But you sure will have to work on your solve block equations anyway, finding additional equations so to make the solutions unique.
Find attached a Prime 10 files with my modifications. Hope it helps! But be aware that you will check especially my functions Qmin and Qmax thoroughly if they really do what you intended!
Sep 19, 2025 6:20 PM UTC
I had a second look at your original Q-functions and I now think (while I still  can't be sure about it) that your A1>B1 etc. lines may simply had been kind of comments and the multiplication with alpha maybe should be done in any case.
Modifying my functions Qmin and Qmax accordingly gives us results which lie more in the magnitudes of the solutions you expect.
Of course the main problem remains - using less equations than variables to solve for.
Sep 20, 2025 3:35 PM UTC
Dear Werner_E, sorry to bother you again. I’m uploading the worksheet with the details of what I actually want to develop, including the conditions. Many thanks for your help.
