Solution ever found for Running Mathcad 6.0 in Windows 7?
It works just fine except you cannot create or save a new file; Mathcad just closes/crashes.
Yeah, I know how old 6.0 is. I use version 13 quite a bit but want to use 6.0 on my laptop.
Thanks for any help you can provide.
Ryan Castle wrote:
...but want to use 6.0 on my laptop...
1. For what ?
2. In this case, you can install in Win7 a Virtual Machine (eg VMWare, running WIN XP or Win 98): http://www.vmware.com/ru/products/desktop_virtualization/player/overview.html
rcastle1-VisitorAuthor
Thank you. So there is no other fix for the problem? That is, make it run in Windows 7 without running a VM?
Another way is to create your own custom portable application. Look at following links:
http://en.wikipedia.org/wiki/VMware_ThinApp
http://www.vmware.com/products/thinapp/overview.html
http://portableapps.com/development
I have a dream to work in Windows with DOS Mathcad (2.5 version)!
Nostalgia!
Smartass
Not helpful.
Yes, you can run MathCad 6 on Windows 7
The best way is to save the entire version on your usb drive as you stated.
Then copy a mathcad file from a different subdirectoy on your usb drive, say from Qsheet, filename symbols.
Paste this file to the subdirectory on the usb drive where you keep your own working files.
Rename file to something like blank1.
Paste again and rename to blank 2.
Do this as many time as you want files for the future. You can do this again if you run out of blank files.
Open file blank 1 and delete contents....type in your work....and save (DO NOT SAVE AS!).
Go to the directory where filename blank1 is located and rename the file.
You now can edit and save the file...but do not SAVE AS....you will lose the changes you made.
Hope this helps.
I have done this 10 times without a hitch.
I think it is the work around you were looking for.
Hi Ryan and all
Please help me to resolve a mystery, which will help us work with Mathcad 6.0 on Windows7 64 bit.
I always told people that any versiom of Mathcad after 6.0 sucks and people would lough at me but now I see that there is a strong conmmunity of people that realize that!!
Anyway what I wanted to say is that I have two PCs with Windows7 professional which save as works with not problem ! on other PCs that I have it doesn't work.
If you know someone that is knowlegable in the internals of Windows he can find what is different in my PC that works and in this way we will solve the problem to everybody.
Maybe something in the registry? premissions?
On one of the PCs where it doesn't work, right click on the program and select "Run As Administrator". Does Save As work when you do that?
No it doesn't help, unfortunately.
