Jan 15, 2010 8:00 AM UTC
Solve Block
I am working on a project where I will being several solve blocks. I have had good success using solve. If I have defined a function in a solve block, can I use it in another solve block? I am pretty sure that you cannot have a solve block within another solve block. But MathCAD may treat a function differently.
Thanks for the support.
David Tietje
>I am pretty sure that you cannot have a solve block within another solve block. <<br> _______________________
Will surely depend upon the structure of the solver(s) involved as well as the Mathcad versions(s). PTC seem to have played a lot in those blocks since Mathcad 11.2a and previous versions.
Attach the block as an image to be reconstructed by users of different versions.
jmG
Jan 22, 2010 8:00 AM UTC
You can not insert a solve block inside another solve block.
Mona
>block.
>Mona
Can we insert if-operators in solve block?
See one task:
http://twt.mpei.ac.ru/MCS/Worksheets/chain-eng.xmcd
Val
http://twt.mpei.ac.ru/ochkov/v_ochkov.htm
Yes. If you define a solve block so that it is a function, then that function can be used in another solve block.
Richard
tietjee15-MoonstoneAuthor
Jan 18, 2010 8:00 AM UTC
Thanks, I will give it a try
David Tg
