Solve Block Error
I am solving two equations in two unknowns. One is linear so I can just solve it, substitute into the other (nonlinear) equation, and use the root function to get the result. This works fine as illustrated in the attached worksheet. But when I try to use a solve block to find both unknowns, I get an error. I am sure I am doing something stupid but I cannot see what it is.
Werner_EAnswer
You typed "e_2" instead of "e2".
Werner_E25-Diamond IAnswer
Aargh. Thanks.
