Solve Blocks
Trying to use Solve for given variable in an equation but doing something wrong
23-Emerald V
I think you made a mistake, it seems like you have Iw (I-omega) as a single variable, If you type them separately with a multiplication in between your solve block might work.
Do you HAVE to use a solve block, or do you just want to solve. 'cause this one is very easy.
agarson1-VisitorAuthor
No, do not have to use solve block but just trying them out.
Thanks for you help.
23-Emerald V
Ok.
Then, did you separate the I from the omega, and did that solve your problem?
