Solve non-trivial solution to a Matrix Function other than the solve block
Hi, everyone,
Right now I just want to find the non-trivial solution to the last equation above,
I can find that using the solve block, but since solve block cannot be used in programming,
I am afraid I have to find another way to solve a Matrix function with non trivial solution.
In Matlab, [eigenval, eigenvecs] = eig (K, M) would return to EV as eigenvecs, using the equation M*EV*lambda = K*EV, and it is easier for programming, say K & M varies.
So is there a way to solve non-trivial solution to a Matrix Function other than the solve block in Mathcad?
Thank you for your help!
Best
Shawn
Werner_EAnswer
In Matlab, [eigenval, eigenvecs] = eig (K, M) can return to both lambda and corresponding EVs, but not sure how to achieve it in Mathcad.
Would this help:
Have you tried "solve, fully" ?
But as long as you don't tell Mathcad that EV should be a vector or matrix, you will just get 0 as solution as this is the only solution of this equation - Mathcad treats EV as a scalar.
sfan1-VisitorAuthor
I tried "solve, fully", but did not work as well.
So is there a way to solve Matrix equation, without using Solve Block?
I just want to make some preparation for the future programming work, if there is.
In this problem, lambda matrix is the eigenvalues of D=K-lambda*M,
then, using the Eigenvecs cannot come out with the right EV.
That's why I use this equation M*EV*lambda = K*EV to find EV.
You can't put a solve block in a program, but you can turn a solve block into a function:
phi(K,M):=Find(EV)
Then you can call phi(K,M) in a program with different K and M,
