Solve to a ratio
Hello all,
I want to solve a formula symbolically according to a ratio.
Here is a simple example:
Does anyone have an idea how I can solve this?
I use Mathcad Prime 9.
Greetings
Philip
ttokoro
ttokoroAnswer
t.t.
ttokoro
ttokoro21-Topaz IAnswer
t.t.
Thank you very much.
Here are my 2 cents for a more generic solution - similar to ttokoros's second approach, but without having to solve   a system of equations.
"simplify" is not necessary for this simple equation, but the approach should work for more a more complex equation, too, if a solution for the ratio is possible at all. If no solution is possible, the result still would contain the variable U1.
Thank you very much. I like this solution.
