Solver cannot find solution even though one exists - Mathcad Prime 3.0
- 6 replies
- 2788 views
- Translate All
I've been working on a problem to determine the formulas for two sinusoidal fibers that are tangent to each other, as shown in the attached picture. I've already pursued this problem with the GRG Solver built into Microsoft Excel and determined that there are multiple solutions, but I wanted to transition to Mathcad. After entering the governing parameters and constraints I found that the solver functions if my guess is the same as one of my solutions, but if I change a guess (specifically for A1 or D1 in the file) it will not solve.
I don't know if I'm doing something wrong with Mathcad or my constraint equations, or if I'm just experiencing limitations of the solver.
I attached my Mathcad file with the most trivial solution entered, as determined by hand. Slightly changing A1 from 1 to 1.1 causes the solver to fail.
Can anyone provide any insight on this? Thanks in advance.
