Solving equations
Can someone help me to find solution for equations which have specific values. I try determinate model for logged signal that. Please see more attached file.
Thanks in advance
Mika
23-Emerald I
That's what solve blocks are for.
You have just two unknowns to solve for but three equations. This usually has no solution. But you can chose two equations and solve:
Find the file attached. It also includes a solve block with minerr, but Fred was faster with this
Here is a third curvefit approach using Mathcad's "genfit" functon to get the same result as the minerr solve block.
Thanks for you quick answer. I appreciate it. This helps me very much
Regards
Mika
(From Finland)
