3-Newcomer
solving symbolic integral equations
Hello, we're trying to solve integral equations, and there's error on getting the final integral value in Mathcad. anyone can direct how to get the following integration done in Mathcad?
There's a following error: More than one independent variable for keyword solve.
23-Emerald V
Change the label of  m and T to variable (they are now seen as a units), and remove the directive solve.
You should see that Prime produces the result of the integral, if it exists, which I expect to be independent of V.
Success
3-Newcomer
Thanks for directions, would you mind please do a zoom call the problem still exists and it doesn't give a correct final answer.
Best regards.
23-Emerald V
Attach the Prime worksheet .
23-Emerald V
Here goes:
That's Mathcad 11.
In Prime 7 you get:
You have to apply mathematical knowledge: in the end (at infinity) the exponential always wins over any power, so the limit results in 0.
It is time they build that into Prime...
