Solving symbolically a system of equations
- February 14, 2013
- 18 replies
- 14559 views
Hello, Iām trying to solve a system of equations symbolically using the Given & Find commands.
Mathcad finds the solution but it wonāt display it because itās too long. It does however mention that the outcome may be further used if allocated to a function or variable. I⦠donāt know how to do thisā¦.
The solution of the system consists of 8 terms: v1,v2ā¦.v8 which will be expressed as a function of the z1,z2,z3ā¦z8,za,zb,zc,zd variables.
I can imagine that the entire solution is very large. Iām interested though only in the formulae found for v1.
Can anyone help in allocating the system solution to a variable and display only the v1 solution?
Andrei
Appended by Werner Exinger:
Hmmm, thats crazy. While a document sure is not the right way to ask for help, I hadn't expected that I would be allowed to edit that post and attach files.
It seems that I am and so I will do.
As I already posted in the comment v1 alone still is too large to display for MC15. I doubt that to be able to view an expression that large and complex would be of any help anyway. As the error message states you are able to use the expression in further calcuations and/or manipulations - you simply have to assign it a variable or function. See attched file for some ways to do.
Appended by Andrei: I'm sorry for posting this question as a document. Following Werner's comments I deleted it out of the document section and copied it to Discussions. In the process I copied Werner's comment.
Werner thanks for showing how the results may be attributed to a variable. It's still quite unfortunate that I can't get a formulae for v1, as z1..zd are in my case other formulaes - this is just a first step for calculating the impedance of a complex electrical network.Finding numerical solutions is not an option for me.
Anyways, your help is much appreciated. Thanks!
