Square Wave as ODE Forcing Function
- 6 replies
- 2686 views
- Translate All
hi,
i wanted to use a square wave to drive a mass spring damper system. i usually use the state space solver, as it has worked better than the other solvers. however, in this case, i get an error. note, the worksheet isn't fully setup yet, due to the error. i was trying to make an example, since there aren't any quick sheets for a square wave.
thanks,
anthony
