SSE vs. ERR variable at a MinERR Solveblock?
Hi Friends,
one short Question:
Is - for an nonlinear model - the ERR variable at a MINERR Solve Block the same as the Sum of Squared Errors? (SSE)
I have different values there.
Thanks for helping and answering.
Walter
Walter,
Compare SSE and ERR^2.
Walter,
The attached sheet should help but Viktor already explained the relationship.
Regards, Werner
Thanks a lot! I also thought that minimizing SSE would be the same as
I think the proper Fitting with least errors is minimizing SSE, right? But why do I not get fine with my sheet? In my second sheet is fine.
No. Minimize the residuals, and use the Levenberg-Marquardt algorithm. Passing the SSE to the LM algorithm messes up how it works, and you get less than optimal results.
