Steady-Periodic Zone Model and Cooling Load Calculation
  • October 9, 2013
  • 0 replies
  • 1181 views
Description:
The model employed for cooling load calculations is the same as the model used for heating load calculations in the previous worksheet. The main difference here is that solar radiation transmitted through windows or absorbed by outside surfaces is calculated in detail. Also, latent cooling load is calculated.
