Stiff ode solvers
I previously posted a version of this question, but did not get any response. So I decided to rephrase and try again.
I have been trying to compare the solvers (BDF, Radua, Stiffr and Stiffb) for stiff odes. Could be doing something stupid but BDF is the only one that I can get to run consistently. For the others I get error messages I do not understand (in this context):
"The return value of this function must match the problem size"
"This value must be real"
(BTW. Documentation says Stiffb does not work for more than 8 equations, but it seems like it should be "8 or more". 7 worked. 8 did not.)
Thanks to anyone who chimes in.
If you run the worksheet, be patient. It takes a while to calculate.
What is the initial setting of the problem that you want to solve with the program?
P.S. Crosspost: https://community.ptc.com/t5/PTC-Mathcad/Error-messages-in-solving-a-system-of-ode-s/m-p/704764
-MFra-
The constant tp is neither defined nor initialized anywhere. How does the processor calculate sin (2πt / tp)?
The solve block is evaluated symbolically and the result is assigned to a function D which has tp (substituted by y[5) as one of its arguments. So all is OK and when you let the sheet run it works OK (at least with BDF and Radau & IC21).
BTW, VladimirN  had unearthed a more than 8 months old question and obviously no one had an idea so far why the solvers other than BDF fail.
-MFra-
Although you work in symbolic, don't you have to initialize the variables first and then reset them for symbolic computation? otherwise if you write tp = ? before the Given, it marks it in red. As a result nothing changes, on this I agree.
