Study 19. Refrigeration Cycles
In the study a description is given for thermodynamic cycles calculations approaches used in refrigeration, air-conditioning facilities, heat pumps. Given the characteristics of cloud-based functions that support these calculations.
Here is a worksheet of advanced exergetic analysis of simple vapor compression refrigeration cycle
Volodya
Here is a worksheet of Thermodynamic Calculations of  Simple Vapor Compression Refrigeration Cycle
Here is a worksheet of the thermodynamic calculations of  Two-Stage Vapor Compression Refrigeration Cycle with Flash Chamber/Regenerative Intercooler
Here is Thermodynamics Calculation of  Two-Stage Vapor Compression Refrigeration Cycle with Flash Chamber and Separate Vapor Mixing Intercooler
Thermodynamic Calculations of  Cascade Vapor Compression Refrigeration Cycle
