Apr 18, 2014 4:43 PM UTC
Sub-Routines at the end of the program
Is there a way to define sub - routines at the end of the program like -
a=3
Ans=cube(a)
cube(a)= a*a*a
PS: I dont want to combine the call function and function definition.....
Thanks in Advance,
Prithivi
Apr 18, 2014 5:13 PM UTC
Yes, you can call one user defined function from within another.
You can even define the called function at the end of the sheet if you use a global definition. But in my opinion global definitions should be used only sparingly if at all as they make a sheet harder to read and debug.
I would rather prefer putting the definitions you want to hide in a collapsed area at the top of the sheet.
Apr 19, 2014 7:02 AM UTC
cube(a):=a^3
