Summation of the function
Hello!
I am trying to sum up all the values of the given function f(x) by using the summation operator.
Variable "x" has assigned values in vector form. How do I proceed here?
Please, take a look at the attached file (Mathcad Prime 6).
Best regards,
Sergey
o.svahnAnswer
You need
for it to be a vector !
kudos
Owe
o.svahn12-AmethystAnswer
You need
kudos
Owe
Sergey15-MoonstoneAuthor
Of course it is - I should have seen it.
Thanks a lot.
23-Emerald V
OK, you transpose the array x, which gives
Then your summation gives:
That is because j is not part of the argument of the summation. If you change the limits for j:
or:
Now if you sum these array values, you get 83, which is the sum of the values of the function results for each of the array elements in x.
To get that straight away, you can index the function inside the summation:
Which is (most probably) what you were after.
Prime is pretty forgiving. Without requiring a transpose, this also works:
Thanks Luc.
But for the correctness sake it may be better to stick with the transpose operator 🙂
Sergey
