Surface plot
i am trying to plot this surface, but it is not showing. not sure what i am doing wrong. Thank you!
See the attached for one possibility. You can play with the appearance to your heart's content.
Alan
Alan
SFares14-AlexandriteAuthor
Thank you Alan!
what was wrong with the way i was doing it? i thought mathcad will draw the surface without "Ceate Mesh" command.
In Mathcad 15 when you are plotting a function, you need write the function name f in the placeholder. and not f(x,y) as you had done.
In Prime you can do write it both ways, function name only or function name with arguments.
Thank you Thomas!
