swiping the input
- 7 replies
- 1350 views
- Translate All
Hi there
I get some results from the balance moments
Now I need to calculate the carry over moments by taking one-half of the balanced moment at a joint and transferring it to the far end of the member connected at that joint. The carry-over moment has the same sign as the balanced moment.
It is it should look like this table
I have to repeat these steps, first calculating the balance moment and then the carry over moment unitl I get zeros in all rows ... and then calculate the final moment by adding all the moments in each joint.
Like this table :
Can you show me how to do that in the attached sheet ?
Yusra
