Symbolic derivative
I am trying to evaluate the derivative of a function symbolically.
Would anybody, please, help me with this issue?
Best regards,
Sergey
LucMeekesAnswer
23-Emerald V
You have to define x(t), that is, use ': ' to get ':=', not set it as a boolean (bold =),.
-MFra-
before the symbolic derivative you must use clear(A), clear(B), clear(t), clear(omega) or also clear(A,B,t,omega), furthermore you have to use the definition symbol " : " for the function definition and not the equal to "=", as Luc says in his post.
Sergey15-MoonstoneAuthor
Thanks for reply.
As long as I can see, it doesn't work.
Would you please use my .mcdx file and apply your suggestion properly?
Sergey
LucMeekes23-Emerald VAnswer
23-Emerald V
Hei,
I used "clear (A)" and then defined "x(t)" as you advised. It worked.
Mathcad's results are complying with my beforehand calculated values.
Thanks a lot.
Best regards,
Sergey
If your goal is to find the derivative but use the value of B you defined and the value of A you found using the solve block, the attached sheet should help.
What had to be changed:
1) B (and possibly x, which later is overwritten by function x) should be defined outside of the solve block
2) no need for x=1 in the solve bock as x IS 1
3) clear variable t (at least for symbolics) - you don't want it to be 0s anymore
4) Make the result of the solve block usable for the symbolics by using the inline evaluation "trick"
23-Emerald V
Sergey uses Prime < 5...
Too bad. Sergey did not mention that.
Here is a pdf printout of the sheet, in case Sergey is still interested.
