Symbolic Equation
- 6 replies
- 4423 views
- Translate All
I am trying to set up a solution for a symbolic equation, but somehow the solution units are not working out correctly. I have attached the worksheet and would appreciate any comments on what is wrong. The result should be in feet, but as you can see, there are three variables that are not being handled correctly.
Also for some reason I get an error message that says "The contents of the attachment doesn't match its file type."
Do I need to save back to an earlier version? I am running MathCAD 15.0.
