Symbolic error message "This value must be a matrix"
- 2 replies
- 2192 views
- Translate All
I'm using MathCad to create a set of linear equations. Everything works as intended as long as I use integer values for some of the elements, but as soon as I change these values to nonintegers I get a "This value must be an Matrix error." I'm sure that I am missing something obvious. The revelant portion of the worksheet is attached below. Thanks in advance.
