Symbolic evaluation
I do not use symbolic evaluation very often so I am sure I am doing something wrong.  The following expression should equal mu_0 . Why do I keep getting the same thing back? Do I need a different keyword (I tried several)  or a modifier?
Werner_EAnswer
No! Why do you think so? Its NOT equal to mu_0, just close for large values of mu_0.
The expression you show "approaches" mu_0 for large mu_0, but is always a bit larger.
Consequently we have
or
For a:=3 we have
Werner_E25-Diamond IAnswer
or
For a:=3 we have
I was actually trying to delete the last post, but could not figure out how to do it quickly enough. But now I get...
ut
23-Emerald V
You cannot delete your post, you can only edit (and empty if you like) it for about a day after it was posted.
23-Emerald V
It's generally a good idea to plot the function you are dealing with:
I guess for a<<1, and mu0 postive, it wil be hard to tell the difference between f(a,mu0) and mu0...
QED.
