Symbolic Solve: "No solution was found"
Having trouble with symbolic equation manipulation. Everything looks OK until I try to use the "solve" keyword to flip-flop a dependent variable with an independent variable.
Stumped. See attached (v11 & v15)
23-Emerald I
October 26, 2011
Andrew Kelly wrote:
Thanks, Andy. Can you explain why it wasn't able to solve for "SF" and why the "SF=sf" statement was required for the solve statement to work?
Is there any info in the help documentation, tutorials, quicksheets, etc. that would have helped me figure this out on my own? Live symbolics doesn't seem to be documented very well.
In orger for the "solve" to work you needed a symbolic equation [=] not[:=] for the symbolic solver to manipulate. When you wrote "SF := " you were making a numeric engine declaration, by introducing "sf", there was an equation to be manipulated.
Is this what you need?
Regards
Andy
Andrewk21-VisitorAuthor
23-Emerald I
October 26, 2011
