Symbolics
I'm echoing values from another work sheet using the Include function.  I want to show a variable equal to the original value but not evaluated to a number.
SYNC bus:=VAZ
I gather that I need to use symbolics.  Can't find the right combination of modifiers.
Werner_EAnswer
This should help:
Next time better post the worksheet, not a couple of pdf's.
Werner_E25-Diamond IAnswer
This should help:
Thank You!  It works!
Related to the above issue.  Attached are fragments of the work sheets in question.
I'm trying to show in the echo sheet the tad of programming for 50G3P and 50G4P in the PARENT work sheet and not the numerical result.
I tried symbolic explicit, ALL.  That didn't work either.
