Template and angle in Mathcad 15
Hello All,
I have two questions concerning MATHCAD 15 M30.
How can we apply, if it's possible, a template to existing worksheets?
How to define angle in degree by default ?
Thanks in advance for your help.
Best regards,
Sidi
RichardJAnswer
You can't, but if you copy the contents of a worksheet and paste them into a template sheet it will take on the formatting of the template.
If you want to define an angle in degrees you have to multiply the number by "deg".
May be so
Sidi Mouatadiri wrote:
Hello All,
RichardJ19-TanzaniteAnswer
Thanks a lot for the response and workaround.
Best regards,
Sidi
