the edit of trail file
hi, guys
here is my problem.
I want to connect pro/e with modefrontier by using trail file. So I first define some parameters in pro/e. However, in the trail file, there shows no parameter name just some numbers.
Does anyone know how to modify trail file, in order to define parameters?
here is a part of my trail file:
~ Command `ProCmdMmParams`
~ Activate `relation_dlg` `ParamsPHLay.TBAddParam`
~ Key `relation_dlg` `ParamsPHLay.ParTable` \
5505140
4718696
524296
524296
4259937
5111918
4653159
3211313
~ Disarm `relation_dlg` `ParamsPHLay.ParTable` \
2 `new_added_row` `name`
5898362
3211313
~ Activate `relation_dlg` `PB_OK`
!Undo: added rec_id 327 type 5204
You posted your question erroneously in the Mathcad section of this forum.
Please chose the appropriate section to increase the chance of getting a helpful answer.
http://communities.ptc.com/community/post!input.jspa?containerType=14&container=2023
