The issue with the analysis of data
As a source of initial data, I use Excel files. When trying to find the values in the table by using "hlookup" function is working for a file "Data 1" and does not work in the case of the data from the file "Data 2". Why?
With "Data 1":
With "Data 2":
23-Emerald V
With "Data 1":
With "Data 2":
Just to add to what Mike's written (I haven't looked at his worksheets yet), for Data 1, hlookup tries to find 1 in the first row of Результаты_тензометрии, which it does in column 1.  The  match function returns 126, so hlookup then returns the value in row 126 of column 1.
However, in Data 2, 1 doesn't occur in row 1 (only 13 and 4.39 are in row 1), so it flags an error up.
Stuart
Is this what you wanted to do?
Mike
Here's another version using lookup.
Mike
Remember hlookup looks in the first row of a matrix.
From the help:
hlookup(z, A, r) Looks in the first row of a matrix, A, for a given value, z, and returns the value(s) in the same column(s) in the row specified, r. When the value(s) are returned, they appear in a vector, starting from the left.
Mike
23-Emerald V
With "Data 1":
With "Data 2":
Stuart
VladimirN24-Ruby IVAuthor
Yes, I missed in the initial data "1". Thank you.
23-Emerald V
пожалуйста, нет проблем, владимир
Stuart
