-MFra-
The two inverse laplace transforms are exact?
By gentleness is there an expert who can tell me if the attached inverse Laplace  transforms are exact?
Thank you very much.
With best regards
F. M.
23-Emerald V
This may help you.
-MFra-
-MFra-21-Topaz IIAuthor
Hallo Luc, excuse me but I don't find satisfactory your reply.
The issue concern the response of an active high pass filter, to a sawtooth signal. I find a discrepancy between the calculated response and that obtained by convolution. for this reason I would like to know if there is an error in the calculation of the response. active filter responses.jpg
With best regards
F. M.
