Oct 13, 2026 5:06 PM UTC
The XMCD, MCD converter is not working on the Demo version?
After many years not using Mathcad, I wanted to load my old datasheet developed in Mathcad 15. I have set up the free version just to have a sense of “Whao.. I like it” but it turns that the converter is not working: no license but I have a license for 30days no?
Please Is there someone to help? I would like to see if the Prime (mathcad12.0) fits my new needs. thanks!
John
    23-Emerald V
    Oct 14, 2026 6:58 AM UTC
    You installed Prime 12, I guess. But did you apply for the trial license?
    If not, tick the M in the top left corner of the Prime window, then select Options, and on the License tab press the 'Get license’ button. The rest should be obvious.
    Oct 14, 2026 9:15 PM UTC
    Oct 14, 2026 9:57 PM UTC
    Undertood. This is because I was woking on a virtual machine.
    Oct 14, 2026 10:01 PM UTC
    But Still I add my worksheet (mathcad 14/15) but got a “Unexpected error encountered during conversion”
    Oct 14, 2026 10:04 PM UTC
    here is the file in case but it will great if I can do it myself. thx!
    Oct 15, 2026 1:05 PM UTC
    Here’s the converted file, but it’s not going to be very useful as it calls for “include” files which were not present, so not converted.
    Alan
    Oct 16, 2026 9:45 AM UTC
    Thanks a lot Alan. I have progressed with your help.
    The last issue is to be able to run the Mathcad worksheet with embedded reference. I have error messages so far.
    Hope I can get your support (or anyone else) that would make the template_… working again. Thx!
    Oct 16, 2026 12:24 PM UTC
    I’ve had a look at your latest files.
    In the useful functions file the routines that didn’t convert contain multiple statements on a single line.  Re-write to put them on different lines.  For example, compare the following:
    Original:
    Prime:
    The physical parameters file has converted without any problems.
    I can’t do much with the main file as it calls text files that are not available to ,me.
    Alan
    Nov 21, 2026 7:20 PM UTC
    The trial license step is worth confirming first, since the converter will not run properly without an active license. For the remaining conversion errors, splitting multiple statements onto separate lines before converting should also help.
