"These units are not compatible"
Hello!
I'm trying to calculate a simple formula but I have some problems with the units. I'm getting the following message: These units are not compatible. Everything is in mm, and I'm using Mathcad Prime 3.0 express. What is the problem?
Use please not floor but Floor!
Thank you!
That worked? Wow, I'm a bit surprised. Doesn't Floor (with capital F) require two arguments. Also, I didn't think floor or Floor would work with units.
