To display graphics
  • April 21, 2012
  • 19 replies
  • 6511 views
Can you tell me how to display
Polar Circle on a H88 (f16, tm, faf1 [abcd) ?
or how to display the values ​​ModuleofH81 50 (f16, tm, faf1) on a graph?
and for PhaseofH811 (f16, tm, faf1) ?
This is very important, thank you for your answers
Best answer by RichardJ
Where do the H8 and H9 Formulae for come from?
http://fr.wikipedia.org/wiki/Filtre_passe-bas
Empirical Formulae Are They? Yes
Well, I don't see those formulae anywhere in that article. All those formulae are based on physics (i.e. not empirical), and the units therefore work fine.
If the formulae really are empirical, then the only way to make them work with units is to divide each occurrence of tpas3 by the correct unit.
PLease help me .....
i don't understand that i can't to display :
ModuleofH81(f16, tm, faf1) ?
and PhaseofH811 (f16, tm, faf1) ?
I want to display the 50 values on 1 graphics for the ModuleofH81(f16, tm, faf1) and not 1 value of 50.
PLease help me ..... THANK YOU VERY MUCH
attached the new file
f16 and tm are vectors with 50 elements each.
faf1[abcd is a range variable. In fact, it is a range variable with only one value, 50000. I can change it to a scalar value of 50000 and the functions evaluate to vectors with 50 elements.
faf1 is not defined at all. What is it supposed to be? A vector with 50 elements? If so, what is the range of values?
Maybe I am wrong, but you seem to have an ongoing confusion about the difference between range variables and vectors. They are not interchangeable entities, but completely different things.
faf1 and faf2 are like Fn(50.05.10^6Hza,tm)
faf1 and faf2 are used like range variable of 1 to 60000 Hertz for pass low filter witj expression H8(faf1)
if you have any questions, please don't hesitate because I can't find the solution
I await your correction, I thank you in advance
